2
This discussion topic has been answered Discussion topic: Paramount plus sky glass conectivity problems
This message was authored by: Vulcan1500
Since changing from sky q to sky glass paramount plus app is not working I have contacted sky they said the problem is with paramount I try to log in on the paramount app won't accept my password used all passwords I could think of still the same  tried the forgot password says asks for email address  then said will send link no emais came through checke spam nothing there either tried the qr code still not working tried online still not working tried my phone app still not working went paramount website same thing tried paramount help got the same instructions as I've already tried just cannot connect and yes we do have a current sky cinema package every other app is fine any help would be grateful slowly losing the will to live with this app
This message was authored by: lettice Answer
Re: Paramount plus sky glass conectivity problems
If you've activated Paramount+ on Sky Q, then upgraded to Sky Glass or Sky Stream, or moved from Sky Glass or Sky Stream back to Sky Q, you'll need to set up your Paramount+ account again.
Follow the advice in activation here;
https://www.sky.com/help/articles/how-to-get-paramount-plus
Avatar for Vulcan1500
Thanks its worked 🙏
Finally that was a hard slog 👍🏻
