9
This discussion topic has been answered Discussion topic: Optical
This message was authored by: Ian591
Optical
Can't connect by digital optical
This message was authored by: BenJoBanjo Answer
Re: Optical
On which device? Sky Glass Gen2 does not have an optical output. Sky Glass Air does.
Re: Optical
Avatar for Ian591
Re: Optical
Sky glass air it's got the port
Re: Optical
What are you trying to connect to it?
Avatar for Ian591
Re: Optical
Got delivered yesterday
Re: Optical
What device are you trying to connect to the optical port on the Glass Air TV? A soundbar?
Avatar for Ian591
Re: Optical
Ultimea sound system works fine on lg tv only brought last year
Avatar for Ian591
Re: Optical
Works with hdmi on ARC
Re: Optical
ARC will give you better sound than optical but if you want to use optical then check that there's light coming through the optical cable from the TV. Try different audio output settings on the Glass menu - try Dolby Digital or Dolby Digital+ if it's set to Auto.
Avatar for Ian591
Re: Optical
Thanks for help will try
