Discussion topic: On screen volume fault
Evening all.
My Glass has acquired an odd problem where the on screen volume icon isn't appearing to show the sound levels.
Unless I press pause the retry and it comes back..
Re: On screen volume fault
Hi @Anonymous
Have you tried the good old remedy of rebooting your Glass TV (off at the plug socket for a minute and then switch back on)?  Reboots will often resolve small software glitches.
This message was authored by: Jporch316
Noticed this on my new (old) 55 glass. It occasionally doesn't show the volume bar although the volume changes.
randomly then starts displaying the bar again after a few minutes
