16
This discussion topic has been answered Discussion topic: My5 Sky Glass not loading
This message was authored by: JaggyB
My5 will not load on my Sky Glass but will play on bedroom TV via our puck. I have switched off at wall. Updated and refreshed app but still nothing. I saw before in another post an email address to contact regarding this problem but can't find it now. Can anyone help me please?
This message was authored by: Fothergill1 Answer
Re: My5 is not working on my sky glass
Hi @Den2410  There a couple of things you could try.
Firstly try restarting the Glass/puck by going into Settings > System Management > Resets & Updates > Restart device.  It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don’t be concerned when this happens.
You could also refresh your Apps by going to the same menu as mentioned above but selecting Refresh Apps.  This process is not immediate and can take up to 24 hours (I believe) to finish the process.  It is done in the background so you can still continue watching your Glass TV.
Other people have been experiencing a similar problem lately. See THIS link.
This message was authored by: Tom-W19
Re: My5 Sky Glass not loading
Hi @JaggyB
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Avatar for JaggyB
Thank you. All working now with the help from Sky.  I really appreciate all the advice given. 👍🏼😊
@JaggyB  It's good news that you are now up and running with My5 😀.  If you have time can you post the solution you were given by Sky as it will help other when they encounter a similar situation.
This message was authored by: Rsimkin
Hey,
Mine is the same can you help?
Just buffering
This message was authored by: Den2410
Has anyone had this problem?  It just stopped working, at first it said technical problems and then just would not load, please HELP!
I am having the same problem too
Could you help me please?
This message was authored by: DEAN132
MY 5 APP NOT WORKING
MY5 app is not working, just keeps buffering and will not load any content. Does anyone know how to fix this?
I have tried to refresh the apps and restart the tv and nothing has worked
This message was authored by: Glad1
My5 app is not loading on my sky glass. It shows me the Milkshake screen and then just goes around in circles
This message was authored by: mick2562
Did anyone get a resolution for this issue as mine still not working
Nope mine still dies not work either.
Avatar for JaggyB
Hiya everyone, It has been a wee while but I think I emailed Sky through the mysky and explained what was wrong and they sent me instructions to follow. I have looked for an email but can't find any. I did everything they advised and it worked.....sorry I am not more help.
Thanks. I will email them.
Answered - Go to Answer
