4
This discussion topic has been answered Discussion topic: Microphone not working on remote
This message was authored by: debbsp
Microphone says that didn't work.
checked WiFi and all good changed batteries on remote
Avatar for debbsp
This message was authored by: debbsp Answer
Re: Microphone not working on remote
Thanks all working now.
@debbsp
That's not a Sky Go issue.
Do you have Sky Q, Sky Glass or Sky Stream?
@TimmyBGood
This appears to be a Sky Glass issue (as there other reports about it) so @debbsp might not come back now as it appears to be fixed according to those posts !
@debbsp  I have seen reports on other threads saying that voice control is working again 🤞
Avatar for debbsp
Answered - Go to Answer
