Discussion topic: Message - Technical Problem. Please try Later.
This message was authored by: ellalia
All afternoon a Message kept popping up, Technical Fault , Please Try Later.
with that the screen went Blank.
In the End I had to turn all the electrical system off, TV, and WIFI - Broadband.
That has cleared the problem for now, then Sky suggest Sky Community,
try them, what a cheek, all the money I pay Sky, and they cannot fix it so try anbody you fancy !!!
NOT A HAPPY CUSTOMER, OVER FOURTY YEARS A CUSTOMER
This message was authored by: Allan95
Re: Message - Technical Problem. Please try Later.
Posted by a Sky employee
