5
This discussion topic has been answered Discussion topic: Just ordered tv does it come with a wall bracket
This message was authored by: Seanyc18
Just wondering if anyone if the tv comes with a wall bracket?
Thank you.
This message was authored by: Deedee36 Answer
Re: Just ordered tv does it come with a wall bracket
@Seanyc18  Yes the sky glass comes with a stand and which can also be used as a wall bracket,just follow the instructions provided,just be aware sky glass is extremely heavy so you may need help fitting to the wall or even consider getting someone in to install for you
“Trying to help improve sky glass”
@Seanyc18  Yes it's built into the back of the tv , you unscrew it to fix to the wall
Avatar for Seanyc18
Level 0 icon
Brilliant thank you
Avatar for Seanyc18
Level 0 icon
Thank you for this
