Discussion topic: Issues with Sky Glass
This message was authored by: Freddie290410
I've been experiencing issues with my Sky Glass TV for a while now.
It's becoming increasingly frustrating, I've tried calling Sky but with very little difference to solving the problem.
Two main issues:
1. It stops/freezes/turns itself off with a "cannot connect to the internet" message. I unplug, restart etc etc and it still won't connect. After a period of time it reconnects, however it is becoming more frequent and in all honesty I don't think it's fair that we have to go through the switch on/switch off, wait for reconnection process almost daily.
2. The second issue which has started more recently is a freezing of the picture and a really awful noise like a jackhammer. The only way to resolve this is to unplug, switch off and switch on, wait for reconnection. Again I don't think this is fair to expect customers to follow this process every time it happens.
Clearly there are technical issues with the Sky Glass TV and I would like Sky to resolve the issue.
Can anyone offer advice on next steps? I've tried calling and I get advised to go through all the steps outlined above. I'm at the point of not wanting the TV any more.
Thanks 👍
This message was authored by: Jporch316
Re: Issues with Sky Glass
Two main issues:
Thanks 👍
Hi
how are you connected to your router ? If WiFi can you try temporarily using an ethernet cable and turning off the wifi in the settings
if the issue persists please report back and I can escalate your post to the online sky community support team
This message was authored by: JHH1
Re your second item, I am often having the same problem with screen freezing and horrendous noise. I carried out routine advised by Sky help but the problem continues. This is an issue which SKY should own up to and remedy.
@JHH1  It sounds as though your Glass TV has developed a fault.  Give Sky a call for some troubleshooting and if it is still within the 25 month warranty you could discuss a replacement.
If Sky is your mobile provider you can phone them by  dialling 150.
If it is not your provider follow this link https://www.sky.com/help/home and scroll down to need more help, click on this and you will see an 0333 phone number to use to call Sky. Unfortunately I cannot include the actual phone number as the forum filters will block it.
Many thanks. I did speak with Sky and they checked things remotely and advised that the issue is likely a break/stutter in the internet connection. Reset and will see how things go.
This message was authored by: Zombie+Warrior
Hi
Im also getting  no2 issues as you are with no answers. Varies from 1-2 times a week to once every 2-3 months ?
Avatar for Freddie290410
Definitely a fault. Got to say I'm struggling with the support, go through resets of the TV but nothing seems to work.
Also tried the ethernet cable and it has stopped the disconnection issue. However, it has developed a "lag" - especially with thevisual picture vs. audio on live sport...the commentary is ahead of the picture and it makes live sport almost unwatchable.
This message was authored by: Mitch100124
Hi
I have had similar issues with the Puck.
*  Screen going black
* Getting a 4 section division on the screen
* lip sinc is out
Done all the resets with sky, checked with the internet supplier and its ok. Got a new puck, the problem frequency has reduced but still there.
I believe there are issues other than the lip sinc i have not been told about.
Were do you go if its not sorted, Legal??
This message was authored by: Anthonywall56
I have the same problem with my sky glass and all I get is switch Internet off and back on again I have Evan gone to sky's super fast Internet witch is not cheap
I'm been having the same issue for over a year with no "fix"
This message was authored by: dm251
I got through to sky a d after them trying from there side decided to replace my tv because they could not reset it
This message was authored by: PhillipT1
Sky Glass and Pug issues
I have had all the problems mentioned above with both the glass and pug.  It is happening on a regular bases, weekly. It's so frustrating I no longer recommend the system to my friends and colleagues.
This message was authored by: vito160
I have had theses problems with the Glass and the pucks for months/years I have always been told it is a local problem (my home) I now virgin broad band 1g so how can it be, but still I get it freezing, no internet connection, waiting to load, sometimes even after adds it asks for my PIN code and I have been watching for 46 mins, it really does have a mind of its own, just a shame I am paying for it to decide when and what I can watch
This message was authored by: ukbigdave2
Wonder how many people need to complain before they find a fix, it's ridiculous. Very easy to blame the internet (on virgin 1gb, funny no other devices have any issues, and resetting Sky Glass resolves it). We are on second TV as returned the first one after 3 months (we complained in the 30 day initial window). Gen 2 is no better.
I keep hoping they will fix via a software fix now more and more people seem to be getting it. If its a hardware issue... RIP!
Does anyone know if using a WiFi->Ethernet bridge to connect the TV via Ethernet will work? Feels like a pretty analogue solution in 2025, but if it works, might have to get one.
