Discussion topic: Internet problems
This message was authored by: Kyle322
Internet problems
My glass tv is connected via Ethernet cable to the router but is still loosing connection intermittently I had this problem last year the internet was upgraded to a fibre connection and the problem had been solved but the issue has started again
This message was authored by: Jporch316
Re: Internet problems
Hi
worth trying to connect with WiFi and not Ethernet to see if the problem persists
