Discussion topic: Internet problems
Message posted on 19 Feb 2025 08:11 PM
Internet problems
My glass tv is connected via Ethernet cable to the router but is still loosing connection intermittently I had this problem last year the internet was upgraded to a fibre connection and the problem had been solved but the issue has started again
Message posted on 19 Feb 2025 10:05 PM
Re: Internet problems
@Kyle322 wrote:My glass tv is connected via Ethernet cable to the router but is still loosing connection intermittently I had this problem last year the internet was upgraded to a fibre connection and the problem had been solved but the issue has started again
Hi
worth trying to connect with WiFi and not Ethernet to see if the problem persists
