Discussion topic: Incorrect pin
Message posted on 31 Dec 2024 06:37 PM
Incorrect pin
Our sky glass was reset and asked for the pin it said incorrect so we have trued to reset using the forget your pin. After adding thw four digits of our payment method and putting in a new pin it is still showing as incorrect. We can't access the tele!!
Message posted on 31 Dec 2024 06:42 PM
Re: Incorrect pin
By default it's the last 4 digits of your mobile number.
Message posted on 31 Dec 2024 08:37 PM - last edited: 31 Dec 2024 08:38 PM
Re: Incorrect pin
@Beck8 wrote:Our sky glass was reset and asked for the pin it said incorrect so we have trued to reset using the forget your pin. After adding thw four digits of our payment method and putting in a new pin it is still showing as incorrect. We can't access the tele!!
Hi
when you see the request for a pin come on the screen pull the plug on the tv. Plug the tv back in and When it boots back up it should skip the pin screen
Message posted on 03 Mar 2026 11:35 PM
Re: Incorrect pin
We are having the exact same issue. Screen stuck on incorrect pin screen. Tv wasn't turning on prior to this so did a reset. Now won't move from that screen
