Discussion topic: Help please! Sold a sky glass
Message posted on 13 Jul 2025 02:26 PM
Hi I've factory reset and sold my sky glass & de-registered it from my account. Buyer is trying to tell me I need to do a code so he's able to use it.
I've called sky and been told not to do that and for the buyer to call up to activate it.
which apparently he now has to sign up to sky to use it, is this correct?
Message posted on 13 Jul 2025 02:39 PM - last edited: 13 Jul 2025 02:39 PM
Re: Help please! Sold a sky glass
@David20202020 Yes, he needs to ring Sky to activate it but he doesn't need to sign up to Sky if he doesn't want to.
Message posted on 13 Jul 2025 03:10 PM
He's begging me to do the code as a previous seller who he brought from previously did it for him on his last sky glass 🫣
Message posted on 13 Jul 2025 03:22 PM - last edited: 13 Jul 2025 03:27 PM
Sounds like he's trying to re-register it on your account to view content you are paying for, or at least re-add it to an active Sky account wether or not that account has an active subscription - to re-enable it as a 'Smart' TV, rather than its current 'dumb' state. Do not do it - it's not your problem anymore.
You used to be able to fully remove devices from within the MySky app, but Sky in their wisdom have removed that ability, and this now requires a call to Sky to action, but as you state you have already de-registered it, I wouldn't worry about it.
Sky Glass 65” [Gen 2]
Sky Glass 43” [Gen 1]
Sky Stream Puck x4
Sky Ultimate TV, Sky Sports, Sky Cinema, Whole Home, UHD&Atmos, Ad Skipping
FTTP Broadband [900/110]
Sky Mobile SIMO x7
Message posted on 13 Jul 2025 03:24 PM
That's exactly what he's doing. He's being very awkward. He paid £150 for a 65 inch tv which he now claims is unusable as he won't find a solution to use it.
Message posted on 13 Jul 2025 03:26 PM
@David20202020 You've done what you needed to do. What happens now is up to him. He can either ring Sky to activate the Glass or he can display it ornamentally.
Message posted on 13 Jul 2025 03:29 PM
@Anonymous wrote:@David20202020 Yes, he needs to ring Sky to activate it but he doesn't need to sign up to Sky if he doesn't want to.
@Anonymous unless he already has an account That's incorrect , he does have to take out the essentials package as a minimum for at least 31 days after which he's free to cancel
Message posted on 13 Jul 2025 03:30 PM - last edited: 13 Jul 2025 03:32 PM
@SKY1992bf My apologies. I thought you could activate it to use without a Sky subscription i.e. just use the Freeview tuner, non Sky apps etc? My mistake.
Message posted on 13 Jul 2025 06:12 PM
Hi @David20202020 the following link explains what your new buyer should do in order to register a second hand Glass TV (and what you needed to do before selling it).
https://www.sky.com/help/articles/buying-sky-glass-second-hand
