Discussion topic: Glass not connecting
This message was authored by: Llissaa
Sky glass can't connect, shows not connecting to internet but tested signal strong
Re: Glass not connecting
Hi @Llissaa  When this has happened to me in the past the following procedure always resolves it.
Put your Glass or puck into Standby and then unplug both your Glass TV (or puck) and router.  Leave for a couple of minutes and then plug your router back in and wait for it to finish rebooting.  Once it has rebooted plug your glass TV back in and when that has also rebooted it should have reconnected to the internet
If that doesn't resolve the issue then have a look at the following links to see if they help:
https://www.sky.com/help/articles/sky-glass-no-internet-connection-osm
https://www.sky.com/help/articles/connect-devices-to-broadband-start
