Discussion topic: FPS Frame rate
Message posted on 06 Jan 2026 12:22 PM
FPS Frame rate
I want help with turning up my FPS on my Sky 55 inch streaming tv which I've had for over 2 years and I am nearly finished paying for it in full.
Message posted on 06 Jan 2026 12:25 PM - last edited: 06 Jan 2026 01:23 PM
Re: FPS Frame rate
@Mackyok1 You can't "Turn up" the frame rate on a Glass TV, or any other Slart TV as they normally have default Frame rates such as 50fps, 60fps etc.
It's not clear from your post what your attempting to achieve?
Message posted on 06 Jan 2026 08:13 PM - last edited: 06 Jan 2026 08:43 PM
Re: FPS Frame rate
Both the first and second generation Sky Glass sets have panels with a 60Hz refresh rate.
FPS (frames per second) is a measure of output, and is typically a function of the graphics chip in a computer or console.
Generally speaking it's undesirable to have FPS output higher than the refresh rate of the panel of a television set being used to display a game: dedicated gaming monitors are better able to cope.
