Discussion topic: FPS Frame rate
This message was authored by: Mackyok1
FPS Frame rate
I want help with turning up my FPS on my Sky 55 inch streaming tv which I've had for over 2 years and I am nearly finished paying for it in full.
Re: FPS Frame rate
@Mackyok1  You can't "Turn up" the frame rate on a  Glass TV, or any other Slart TV as they normally have default Frame rates such as 50fps, 60fps etc.
It's not clear from your post what your attempting to achieve?
Re: FPS Frame rate
@Mackyok1
Both the first and second generation Sky Glass sets have panels with a 60Hz refresh rate.
FPS (frames per second) is a measure of output, and is typically a function of the graphics chip in a computer or console.
Generally speaking it's undesirable to have FPS output higher than the refresh rate of the panel of a television set being used to display a game: dedicated gaming monitors are better able to cope.
