Discussion topic: Ethernet connection
This message was authored by: Spyglass
Message posted on 02 Jan 2026 06:59 PM
Ethernet connection
Can somebody help? I am trying to connect my Skyglass TV via an ethernet cable. The TV says 'No IP address found' and 'If IP address allocation is disabled on your router you will need to enable this before continuing'.
Find out more
Message posted on 03 Jan 2026 08:42 PM
Re: Ethernet connection
Hi @Spyglass
Who is your ISP? Is it a standard set up? I.e. are you using isp kit? Do you know if DHCP is enabled?
I would power off your TV, reboot your router, wait for it to come back online and then try again. Also out of interest what happens if you connect via WiFi?
MikeAlanR
