Discussion topic: Control issues
This message was authored by: Leesmith111
Message posted on 05 Oct 2024 04:48 PM
Control issues
Return button on control doesn't work when watching discovery plus
This message was authored by: Stephen+Mourton
Find out more
Message posted on 05 Oct 2024 07:00 PM
Re: Control issues
@Leesmith111 I have just tried it on mine, I put the live rugby on and then used the return button, it took 4 presses to get completely out. Of course you could just use the voice button to take you where you want.
Find out more
Message posted on 05 Oct 2024 10:23 PM
Re: Control issues
@Stephen+Mourton - Congrats on being the top contibutor for Septmeber 👏👏
