Discussion topic: Connection
This message was authored by: Painless1
Message posted on 21 Apr 2025 01:30 PM
Connection
Each morning when I turn on my Sky Glass I can't watch anything apart from a black screen. This is resolved after turning both the router and TV off and back on. This is obviously a fault but how to fix is the problem. HELP
Find out more
Message posted on 21 Apr 2025 01:37 PM
Re: Connection
Hi @Painless1 I had a similar problem when I first moved to the streaming platform. Like mine,, your puck is probably losing the network connection when it is in standby so go into the Settings > Start up & standby menu and make sure that the option for "Networked standby mode" to ON. I would also turn OFF the overnight power saving. It resolved the issue for me so hopefully iy will do the same for you.
