3
This discussion topic has been answered Discussion topic: Connecting Sky glass to EE mobile broadband
This message was authored by: PN77
Hi we've recently moved house and I can't seem to connect the sky glass to the internet. The glass finds the router and connects but says no internet. There was 35mps this morning and I've tried WiFi and Ethernet connection but still no joy. Thinking it's a port issue as I can access the internet and stream YouTube on phones and computer. Any ideas?
This message was authored by: mikealanr Answer
Re: Connecting Sky glass to EE mobile broadband
Hi @PN77
There could be a few things here. Although you have connected via ethernet ensure that you have disabled WiFi in the settings on your glass as it will still try to connect via WiFi. It may be worth while resetting the network connection and then just plug your cable in.
https://www.sky.com/help/articles/sky-glass-no-internet-connection-osm
The other thing is the speed is very close to the minimum supported by Sky. They say you need 25Mbps for HD and 30Mbps for UHD. Obviously there isn't a lot of headroom if your speed is 35Mbps.
The other thing is might be worth checking with EE if streaming devices are supported. I know with the backup broadband 5G router things like teams and web browsing work as normal, but Glass / Stream don't on the odd occasion I've had to fallback. Not sure if they limit mobile brosdband.
I assume you are waiting for a BB to be activated, if you disconnect your Glass from the internet and you have an aerial you will get some Freeview (DTT) channels. See: https://www.sky.com/help/articles/tv-input-app-on-sky-glass
MikeAlanR
This message was authored by: peter-marlow+1966
Sky glass  tv needs a minimum  of 25mps just to work on its  own if you are only getting  35mps  and you have other devices  connected  to the Internet  then that will  probably  be your  problem  with  the tv, I would say you  need to have at least  50mps  going  to the hub and not mobile  broadband  but normal broadband
P c marlow
Hi @PN77
MikeAlanR
This message was authored by: Jporch316
The other issue you may have is the consistency of signal is of great importance and this can fluctuate a lot with mobile internet
Answered - Go to Answer
