2
This discussion topic has been answered Discussion topic: Channels won’t work and I can’t stream
This message was authored by: Karen1203
Switched TV on but every channel I try to watch won't load and then says there is a technical fault with that channel!
I also can't stream anything!
This message was authored by: Fothergill1 Answer
Re: Channels won’t work and I can’t stream
@Karen1203  Have you rebooted your glass TV if not try the restart procedure as follows: Go into Settings > System Management > Resets & Updates > Restart device.  It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don’t panic when you first start the process.
Avatar for Karen1203
Thanks for your reply. I had to switch everything off and try again. It did work to an extent. I lost all my apps though. Those are now back. I really hate Sky Glass. Too many glitches all the time!
Answered - Go to Answer
