Discussion topic: sky air
This message was authored by: fulhamfc1
sky air
already have sky q. was thinking if i buy a sky air tv would it connect to wifi by internet to use in the bedroom
This message was authored by: Gincap
Re: sky air
You can't have Q and Glass it is one or the other.
If you go down the Glass streaming road do your homework, you need excellent WiFi coverage or hard wire via Ethernet cable.
Plenty of videos on YouTube or pop into a Sky Store or booth at a shopping centre.
Re: sky air
Hi @fulhamfc1 As advised by @Gincap it's Sky Q or Sky Glass.
However, for the bedroom have you considered a Smart Freely TV and a subscription to NOW TV for the Sky content.  You will get pretty much the same content as you would get with the Sky Air but at a much cheaper outlay and monthly cost.  Another option would be a standard smart TV together with either an Apple TV or Amazon Firestick (plus a NOW TV susbscription).
