Discussion topic: depth of 43" sky glass with wall mount
This message was authored by: TW16
We want to get a 43" sky glass. We are having a wall cabinet bult for it. How deep should it be? What depth is the TV & the wall mount?
Re: depth of 43" sky glass with wall mount
@TW16
48mm plus a few mm for the mount spacing.
Personally I'd suggest you try to get to see one in place to assess the effect.
Note that you're going to obscure both the side facing L/R speakers and the upfiring Atmos drivers if you surround it completely.
