Discussion topic: Why carnt I click Netflix to come on my sky glass
Message posted on 14 Jan 2025 07:25 PM
When I go to get Netflix on it's not working why I use all time would like to watch a film tonight
thanks Andrea
Message posted on 14 Jan 2025 07:48 PM
Re: Why carnt I click Netflix to come on my sky glass
@AndreaJ2 Have you tried a reboot
“Trying to help improve sky glass”
Message posted on 15 Jan 2025 10:58 AM
That happened to me a couple of times at first. I thought Netflix was down, but I've. found I could watch iton my ipad, etc. I found out that if you turn the sky glass off and unplug it from the mains and leave it for a couple of minutes, plug it back in again It should work..
Message posted on 15 Jan 2025 11:22 AM
Alternatively you can reboot via the settings rather than having to acccess the plug socket.
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
One way to avoid having to do the reboots is to ensure you are exiting the apps when you have finished watching them. Don't just press the home button to "exit" the app, press the back button u til the app closes or it brings up the apps menu where you will find an "exit" button. Note the way of exiting each app is different depending on the app.
