6
This discussion topic has been answered Discussion topic: Sky Glass aerial input problem
This message was authored by: philrat64
Hi, has anyone else had this problem, my tile for aerial input is no longer there in the input section, just the three HDMI tiles. It used to be there and worked fine, I've turned the Wifi off restarted, unplugged, done all the usual stuff many times, but still no joy. Thx
This message was authored by: peter-marlow+1966 Answer
Re: Sky Glass aerial input problem
This will only show  when there is no Internet what so ever and will  not show while  you  are connected  to the Internet,
P c marlow
Avatar for philrat64
build version. QS028.516.00P
I have refreshed the apps, unplugged and restarted again and still just the HDMI tiles. Also the WIFI automatically turns itself back on everytime the TV is turned on, is this correct?
P c marlow
This message was authored by: Jporch316
As stated it's only there as a backup option when the tv loses an internet connection ......
This message was authored by: Teeh2001
The aerial app is or was visible as an input source app, currently  visible on my sky glass whilst connected to the Internet.
It was visible on my sky puck but has now disappeared, was working fine on the puck connected to the Internet.
Hi @Teeh2001
Yes Sky have now made this available on Glass, however it was enabled in error on the pucks according to another thread.
MikeAlanR
https://helpforum.sky.com/t5/Sky-Stream/TV-input-App-has-appeared/m-p/4880812/highlight/true#M43701
