Discussion topic: White picture with sound
This message was authored by: philwalker
Just had Sky stream installed today but already had 2 isdues with losing the pocture but syill have sound. Once using streaming Sky Atlantic and again watching BBC 24 hour channel live. Both problems within 2 hours of each other. What is causing these faults?
Re: White picture with sound
Normally it's the broadband connection.
Sky Stream relies entirely on you supplying the puck with a fast and stable broadband connection. Without that it simply will not work very well. The Stream pucks are quite sensitive to speed fluctuations and, unlike most other streaming devices and services, much of the SkyOS platform runs from Sky's server, not on the puck itself. It is therefore critical that you provide as good a connection as possible, otherwise it's pointless having Sky Stream.
