Discussion topic: When is QS014 due?
This message was authored by Anonymous This message was authored by: Anonymous
Re: When is QS014 due?
@Jporch316 wrote:
@Anonymous
apple fanboys are always last 😂
@Anonymous  best thing they could do is to remove CW rail completely until they get it working .........
100% agree I've said the same just do away with it and clean up Playlist.
Or move the CW rail under the playlist menu and then it is hidden away not in your face.
Job done!
@Chrisee  May be wrong but can't see any benefit for the pucks getting  this release as it's aimed at the Glass TV side mainly?
The bug fixes and voice control are useful. The only Glass specific feature is the bluetooth audio.
@Jporch316 think I'm being punished for being too outspoken (and an Apple fanboy). At least there will be better discussions than 'my continue watching rail is playing up today', driven me spare the last couple of weeks.  I'm with you, scrap the thing and concentrate on the playlists.
still on QS013
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Technically if you opt out of CW via the link below then the rail should disappear for you, it may not be instant but it will go.
Then of course when CW is confirmed as fully fixed you could turn it back on. Plus it will essentially purge any stubborn things that don't remove.
https://www.sky.com/mydetails/data-and-personalisation
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
This message was authored by Fothergill1 This message was authored by: Fothergill1
Thanks,
Tim
@Tim+Adams Maybe too many people have taken your advice and clicked on the link as it has collapsed like the CW rail 🤣. It's the usual "Whoops, there's been an error" message
If my post has solved your issue please mark as an "Answer"
Thanks,
Tim
Typical, the problem is resolverd and the link is working now 😀
This message was authored by skillwill This message was authored by: skillwill
Looks like mainly a bug fix update – totally welcome and makes sense, you'd imagine they weren't working on new features/releases over Xmas/New Year.
82bit
This message was authored by 82bit This message was authored by: 82bit
I ignored most of the advice here and got a Sky Glass TV! (Loving it by the way). Updated to QS013.503.00P only. Hopefully 14 will drop on it before too long.
Sky Glass 65” with Sky Live
Sky Glass 43” with Sky Live
Sky Stream Puck + Sky Soundbox
Sky Stream Puck x3
BT FTTP:
↓920Mbps
↑110Mbps
@82bit Like you I am also happy with my Sky Glass. I can't remember the last time I was forced to do a reboot 😀.  Certainly it is no more often than I had to do it with Sky Q.
The Glass hardware if fine (I can't comment on Stream) but like many on the forum I am totally fed up with the inadequacies of the CW rail, playlist and the progress bar. I have no doub't that Sky will get it sorted but I hope it doesn't take them too long. I clearly remember that Q had many issues when it was first released.
My pucks have updated overnight to QS014.005 which is labelled as Entertainment OS1.1. Can confirm the new Play boice command works assuming there is a clear target like a movie title.
This message was authored by Paul+Boland This message was authored by: Paul+Boland
My Sky Glass has updated from QS014.004.00P to QS014.005.00P
My Sky Stream Pucks has updated from  QS13.007.02P to QS014.005.00P
82bit
Anyone know what criteria Sky use to determine how they push the updates out? Is it by install date or serial number batches or similar?
Sky Stream Puck x3
BT FTTP:
↓920Mbps
↑110Mbps
This message was authored by Jporch316 This message was authored by: Jporch316
@82bit  On how good you have been - see @Anonymous   😂
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
This message was authored by Deedee36 This message was authored by: Deedee36
One of my pucks updated last night and as if continue watching wasn't bad enough before hand it's worse now,as soon as I start to watch a show it thinks I've watch to the end and the blue progress bar is showing fully watched and the rail is updating to the next episode even though I may be only 10 minutes into to what eposide im currently watching........how oh how can they get this so wrong ????
“Trying to help improve sky glass”
