Discussion topic: Voice command not working on sky glass after contacting them
Message posted on 23 Nov 2025 09:26 PM
7 days voice commands not working
Message posted on 23 Nov 2025 09:59 PM
Re: Voice command not working on sky glass after contacting them
Hi @Miller132
You will need to provide more information. We are fellow customers here not sky and have no idea who you contacted..
Is this the hello sky commands or is this pressing the mic button on your remote? What happens? Is there an error? Please provide as much information as you can.
MikeAlanR
Message posted on 23 Nov 2025 11:57 PM
Hi @Miller132 and welcome to the forum. I used to have Glass but now have a stream puck. When either of them lost voice control in the past a reboot always resolved it for me.
To reboot you can either remove the power cable from the plug socket for a couple of minutes or go to Settings > system management > startup & standby > restart device. Whilst the device is rebooting the screen will go blank for a while until the Sky logo appears. It takes a couple of minutes to fully reboot.
Message posted on 24 Nov 2025 01:49 PM
@Miller132 wrote:7 days voice commands not working
Hi @Miller132
The following worked for me when the voice commands stopped working on my glass
Switch tv to standby (either with remote, or with button on side of set)
Switch off at plug
Switch on at plug (no waiting necessary)
When red standby light comes on, press Home button on remote.
