Discussion topic: Upgraded broadband Sky Glass keeps freezing
This message was authored by: NattyNoo2020
I upgraded sky ultra fast and since installed the sky glass telly keeps crashing and losing signal it happens at least once if not multiple times every evening and it's been happening since it was installed didn't have this problem before it's very frustrating.
Re: Upgraded broadband Sky Glass keeps freezing
Have you reported the issue to Sky?
Avatar for NattyNoo2020
I can't find how to do this?
This message was authored by: Skull+Treaty
@NattyNoo2020
You can call on 150 from a Sky Talk Line or Sky Mobile.
https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number. If you are in the ROI on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
