Discussion topic: Total lock required for Sky glass
This message was authored by: NoiamSpartacus
I need to be able to totally lock Sky glass to control my kids tv screen time! Does anyone know how to do this? Ratings based locks and app locks are not sufficent.
Re: Total lock required for Sky glass
Hi @NoiamSpartacus
It's not possible. The only suggestion would be to get a smart plug and control the power, but would only work if socket not easily accessible.
MikeAlanR
@NoiamSpartacus
There's no function in the operating system or GUI for that.  Sky Glass is really not ideal for such limitations, given the built-in voice control.
This message was authored by: Padam_Padam
@NoiamSpartacus
The only possible solution, depending on your broadband supplier, might be to investigate some kind of network availability timer whereby the broadband connection to your Glass TV is shut off at specific times of the day. Without a network connection (or backup aerial) Glass becomes a big dumb monitor.
Some routers have this kind of capability built in to their software. You would access the control panel via a web browser to set it up, but you'd need to seek specific help based on your ISP and router.
