Discussion topic: Technical issue
Message posted on 26 Jan 2025 02:58 PM
Technical issue
I've been trying to set up sky stream on my Tv, I get as far as the sky symbol and if I try to go further it says: sorry, because if a technical issue you're currently experiencing a limited service.
Message posted on 26 Jan 2025 03:21 PM
Re: Technical issue
Hi @Joannac and welcome to the forum. Sometimes a simple reboot/restart will resolve the issue. To do this go to Settings > System Management > Resets & Updates > Restart device (do not do a factory reset). It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don’t worry when this happens.
If that doesn't sort out the problem have a look at THIS trouble link for the technical issue response.
Message posted on 26 Jan 2025 05:03 PM
Re: Technical issue
Ok thankyou. I'll give it a try.
Message posted on 26 Jan 2025 05:06 PM
Re: Technical issue
Please can I just check, is this by using the remote control as there isint any of these options on my Tv when I try to set it up. Or do I try this on my sky app?
Message posted on 26 Jan 2025 05:12 PM - last edited: 26 Jan 2025 05:15 PM
Re: Technical issue
Hi @Joannac Use your remote to go to the Glass TV home screen and you will find the settings right at the bottom of the page. The easier solution is to use the voice button on your remote and just say "Settings" and it should take you direct to the settings menu.
Once in the setting menu select "System Management" then "Resets & Updates" and then select "Restart device"
Good luck 🤞
Message posted on 26 Jan 2025 05:33 PM
Re: Technical issue
Bit of a problem I haven't got glass Tv.
Message posted on 26 Jan 2025 05:37 PM
Re: Technical issue
@Joannac Ah, you posted in the Glass TV forum so I made the wrong assumption. As you have not finished setting up your puck you would not be able to get to the menu I have been suggesting so I will escalate your original post to the Sky Community Messaging Team for some online trouble shooting.
The link below explains how the procedure works
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Keep a look out for the speech chat bubble that will appear on the bottom left of your screen when you are logged onto this forum (you will need to refresh your browser from time to time until you see the chat bubble). When the blue bubble does appear you have 48 hours to respond or the chat will be automatically closed. Note replies from Sky are not instant so you will need to regularly check the chat thread.
Message posted on 26 Jan 2025 06:44 PM
Re: Technical issue
Hi ok no worries. Thankyou for your help.
Message posted on 27 Jan 2025 11:27 AM
Re: Technical issue
Thanks for escalating this. We’ve sent an invite to chat.
Message posted on 27 Jan 2025 11:32 AM
Re: Technical issue
Ok thankyou
