		Discussion topic: Technical fault
	This message was authored by: Neenee1
		Message posted on 06 Mar 2025 05:26 PM
							Technical fault
I am unable to load any channels on sky glass. It try's to load then says technical fault try later
Find out more
		Message posted on 06 Mar 2025 05:29 PM
							Re: Technical fault
First, turn your Glass off at the plug for a few minutes.
