Discussion topic: Sky stream issues
This message was authored by: Nk58
Sky stream issues
Hi
i e tried setting up the sky stream,
I get as far as the software needs to restart, I pressstart update, 5 mins later, it just goes back to. The software needs to restart.
tried all the sky options.
help needed please?
thanks
Re: Sky stream issues
@Nk58 wrote:
Hi
help needed please?
thanks
Connect the puck directly to your router with an ethernet cable to allow the software update to complete.  You should then be able to revert to using WiFi.
There seems to be a history of pucks not being able to update on first boot over WiFi.
Avatar for Nk58
Thank you, I will order a Ethernet cable now
cheers👍
