Discussion topic: Sky’s hub and sky glass tv
Message posted on 24 Oct 2024 07:10 PM
Hi I'm getting a sky glass tv in a couple of days, do I need to upgrade from my Skye hub I have owned for approximately 4 years or will it work ok
Message posted on 24 Oct 2024 07:12 PM
Re: Sky’s hub and sky glass tv
Sorry that should read SKY Q HUB
Message posted on 24 Oct 2024 07:15 PM
@PeteM2 wrote:Hi I'm getting a sky glass tv in a couple of days, do I need to upgrade from my Skye hub I have owned for approximately 4 years or will it work ok
Sky glass works with any router or internet provider as long as you have at least 30mb of speed and a good wifi signal
Message posted on 24 Oct 2024 07:51 PM - last edited: 24 Oct 2024 07:54 PM
The Q Hub was never great for WiFi, but as @Jporch316 indicates, it only needs to deliver the minimum bitrate Glass requires for the resolution of the content being viewed.
Perhaps worth noting that Sky will be replacing all Q Hubs over the next year or so anyway because they aren't compatible with the end of PSTN service.
Message posted on 25 Oct 2024 07:03 PM
What is your broadband speed ?, I got my sky glass tv , in november 2021, I changed my hub to a sky max hub, and January this year I upgraded my broadband to sky gigafast 900mps full fibre broadband to the property
Hope this helps you
