1
Discussion topic: Sky remote not working and won’t reset
This message was authored by Dee75 This message was authored by: Dee75
Sky remote not working and won't reset
This message was authored by Fothergill1 This message was authored by: Fothergill1 Answer
Re: Sky remote not working and won’t reset
@Dee75Welcome to the forum.
To help you try to get your remote working the links below are to remote troubleshooting guides:
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
If my post has solved your issue please mark as an "Answer"
