Discussion topic: Sky glass wall mount
This message was authored by: ClareBear74
Best wall mount for Generation 2 55inch to
Re: Sky glass wall mount
@ClareBear74 VESA wall mounts are compatible with the Gen Two. Just make sure it and your fittings can support the weight of the TV.
