11 Oct 2023 11:26 AM
Hi can anybody help my sky glass remote has completely stopped working I have changed the batteries I have done everything it says on my sky app, turned the tv off and back on again nothing seems to be working can someone help (Thank you)
only had the tv about a month.
11 Oct 2023 02:47 PM
Posted by a Superuser, not a Sky employee. Find out more@Marie75 Try to pair the remote again as follows:
You may have already tried the help/toubleshooting guides for the remote but just in case I have put the links below.
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine).
If none of the above works then post back here and I will escalate your problem to the Community Messaging team for them to sent you an online chat invitation.
In the meantime, If you have one available you can use a Sky Q remote whilst you get the issue resolved..
08 Dec 2023 07:46 AM
Hi thanks for replying
I did all that, I had to get in touch with sky they sent me a new remote out
