Discussion topic: Sky glass remote
This message was authored by Sian2002 This message was authored by: Sian2002
Sky glass remote
So my sky glass remote just randomly started pressing the wrong things, for example I press the power button and it turns the tv up or I press the home button and it turns the tv off, is there a fix ?
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Sky glass remote
@Sian2002  I have just replied to another thread with the same problem.  The folowing is a simple cut & paste of my reply (I'm being lazy 🤣)
Try to reset and then re-pair the remote as follows:
  1. Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
  2. Press 4 and 6 together for three seconds (IR mode).
  3. Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
If that doesn't help have a look at the following links to troubleshooting guides:
Troubleshooting guide
Remote help
If none of the above works then phone Sky to discuss and request a replacement remote.
If you have one available you can use a Sky Q remote.
If my post has solved your issue please mark as an "Answer"
