09 Aug 2023 08:56 PM
So my sky glass remote just randomly started pressing the wrong things, for example I press the power button and it turns the tv up or I press the home button and it turns the tv off, is there a fix ?
09 Aug 2023 09:02 PM
Posted by a Superuser, not a Sky employee. Find out more@Sian2002 I have just replied to another thread with the same problem. The folowing is a simple cut & paste of my reply (I'm being lazy 🤣)
Try to reset and then re-pair the remote as follows:
If that doesn't help have a look at the following links to troubleshooting guides:
If none of the above works then phone Sky to discuss and request a replacement remote.
If you have one available you can use a Sky Q remote.
