17 Jun 2023 09:58 PM
My sky glass remote doesn't seem to be working for example when I prese the left hand side on my remote ( on circule but , where you Would press left) it seems to turn my tv off. It's like my remote is out off tune please can someone help me
17 Jun 2023 10:04 PM
@Tino128 wrote:My sky glass remote doesn't seem to be working for example when I prese the left hand side on my remote ( on circule but , where you Would press left) it seems to turn my tv off. It's like my remote is out off tune please can someone help me
Follow the troubleshooting here:
17 Jun 2023 10:08 PM
Posted by a Superuser, not a Sky employee. Find out more@Tino128 Try a hard reset of the remote as follows:
With Glass / puck turned off at the wall:
Hold 4 & 6 for 10 seconds
Hold 7 & 9 for 10 seconds
Turn on glass / puck & wait for it to reboot & go to homepage
Hold 1 & 3 until it says it is connected (or follow on screen messages)
If you still have a problem have a look at the following link and follow it through. At the end if you have not resolved your issue click the button for needing more help and it gives a phone number to call.
https://www.sky.com/help/articles/remote-control-help-sky-glass
Good luck 🤞
