Discussion topic: Sky glass remote wont sync
This message was authored by Sarah1978 This message was authored by: Sarah1978
  • Hi our first sky remote has stopped working and we bought a new one from sky's amazon approved seller. New remote refuses to sync. Even though the old remote has been removed.  Tried all the usual tips on Sky,  nothing working. Please help!!
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Sky glass remote wont sync
I'd try the following. But I'm not sure why you purchased a new remote if your other one was faulty instead of requesting a replacement from Sky. The details on how to request a replacement for a faulty remote are at the bottom.
Check the batteries
An easy way to check is to cover the buttons slightly on your Sky remote with your hand. You should see a white backlight behind the buttons. If you don't see the backlight the issue is the power with the remote, so potentially a battery issue.
Check the battery compartment to make sure the paper used to protect the battery has been fully removed. It might have ripped when being removed leaving some behind.
Still can't see the backlight? It’s likely you need to replace the two AAA batteries.
Pair the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel. It
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
