Discussion topic: Sky glass remote not working.
This message was authored by Jennifer1989 This message was authored by: Jennifer1989
Basically what it says in the title. Up, down, left and right button not working at all, as well as certain numbers. I've tried everything and it's just not working.
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Sky glass remote not working.
@Jennifer1989
Unfortunately there is a fault with many of the remotes as Sky received a bad batch from the manufacturer. There is a huge thread here (along with many others) about the problem:
https://helpforum.sky.com/t5/Glass-Stream/Stream-remote-completely-unresponsive/m-p/4197584#M77629
As strange as it sounds, the one fix that has worked for a number of people (including me, twice) is to hold the remote at both ends and gently twist as though you were wringing out a cloth.
Even if this fix worked I would still phone Sky and request a replacement.  Also, in the short term, if you have access to a Sky Q remote it will work with Glass or Stream.
Good luck 🤞
If my post has solved your issue please mark as an "Answer"
