3
This discussion topic has been answered Discussion topic: Sky glass remote can’t reset
This message was authored by: Darren5473
Hi when I try to do voice control. It says press 1&3 to connect remote I have tried but nothing I have changed batteries and tried pressing 7&9 to reset but still all same not sure what else to do
thanks
Avatar for Darren5473
Level 2 icon
This message was authored by: Darren5473 Answer
Re: Sky glass remote can’t reset
Just done it had turn tv of at plug and reset it all done know
Follow this step-by-step guide. If after trying each step it still doesn't work then you may need to order a replacement from Amazon:
https://www.sky.com/help/articles/remote-control-help-sky-glass
Level 2 icon
Hi thanks tried all them
Level 2 icon
