Discussion topic: Sky glass red standby light flashing
This message was authored by Aaron43 This message was authored by: Aaron43
Hi my 43 inch sky glass keeps going into a mode where the standby light flashes.  I have to keep switching it off to reset it.  Is this something I should be worried about.  It's happened 5 times in the last week alone.  Is it updating or is it a possible fault?
This message was authored by Jones_The_Cat This message was authored by: Jones_The_Cat
Re: Sky glass red standby light flashing
If you've had it for less than two years then you should ring Sky for further troubleshooting and request a replacement under warranty if it continues to do this.
