Discussion topic: Sky glass not working
Message posted on 19 Oct 2025 04:30 PM
When we try and go onto sky glass we have this error message
Sorry, because of a technical issue, you're currently experiencing a limited service. Please be assured that we are risking hard yk fix the problem.
We have been getting this message for a couple weeks now.
Message posted on 19 Oct 2025 04:32 PM - last edited: 19 Oct 2025 04:33 PM
Re: Sky glass not working
Unplug the TV give it 5 minutes and reboot hopefully this will clear any software issues. Also check your WiFi quality you can do this in settings. If your WiFi is weak then look at hard wiring with an Ethernet cable to your router.
