Discussion topic: Sky glass not working
This message was authored by Luke+Foxyy This message was authored by: Luke+Foxyy
I just returned from a week long holiday and trying to turn my sky glass on without sucess. I've switched it off/on several with no luck. Any help?? Cheers
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Sky glass not working
@Luke+Foxyy That sounds as though it could be terminal.
When you have switched in on/off I assume this is at the plug socket.  After doing that it should take about a minute to reboot before the standby light comes on.  Are you seeing the red standby light at the bottom middle of the TV set?
If not I would check the fuse in the plug and the breaker at the distribution board.  If both of those are OK then I think you will need to phone Sky and tell them you have a dead Glass TV.
Good luck 🤞
If my post has solved your issue please mark as an "Answer"
