Discussion topic: Sky glass keeps buffering and dropping out.
Message posted on 16 Sep 2024 07:17 PM
Message posted on 17 Sep 2024 07:21 AM
Re: Sky glass keeps buffering and dropping out.
What is your router's sync speed to the internet?
What is Glass TV's connection speed to the internet using the Netflix Network check?
How is your Sky Glass TV connected to your router WiFi or Ethernet?
Who is your ISP?
Message posted on 18 Sep 2024 01:29 PM
Exhaled in H&H
Thank for your reply,not sure of sync speed,,it's also done by WiFi.
I did wonder if earthnet cable might make a difference, I will try that
Many thanks Mick Packham
Message posted on 18 Sep 2024 03:13 PM
Your ISP will have given you an estimate of your sync speed ... if you log on to your router you can find the actual sync speed under stats😉
