Discussion topic: Sky glass freezes - NOT using WiFi
This message was authored by: K11
Sky glass keeps freezing then either restarts or need to power off on.
WiFi is off - using Ethernet to EE plus router with FTTP (during glitch other devices never dip below 700 Mbp/s).
WiFi off in sky glass settings. Problem has got more frequent- at least twice daily.
entertainment os 1.3
build v qs030.520.00p
sky live v CH000.043.1P
hardware model LT055-f2-wht
sky live hardware model VC100-ant
ui v 20.289.030.07
This message was authored by: peter-marlow+1966
Re: Sky glass freezes - NOT using WiFi
Can you  connect the tv with an ethernet cable  it is more reliable,  I have my tv connected  that way and have no problems,  55inch sky glass tv  fftp  with  sky gigafast  900mps,  I used  to have problems  with  my  wifi when I had sky q got a sky engineer  out at the time and he installed  an ethernet cable  to that and the freezing  problems  stopped  so when I changed  to sky glass  I just  connected  the tv the same way
P c marlow
ui v 20.289.030.07
Did you reboot the Glass TV after turning WiFi off ... and checked it was still off?
I already  had the ethernet cable  and when the tv arrived  before  turning  it to set it I plugged  the cable  in and  when setting  it up I turned  the WiFi off and it's  still  off nearly  3 years  later
P c marlow
Avatar for K11
Yes, restarted and can confirm WiFi is off.
This message was authored by: Mister_Dalek
There have been issues recently with Sky Q and EE routers. I wonder if there's something similar going on here with Sky Glass.
Might be worth giving Sky a ring.
This has just started happening to me.
had the Sky Glass for three years, it's always been connected via Ethernet. Never had an issue until this last week.
I run my own aerial, satellite and tech business (for 21years) so know how to fault find. Here's what I have done:
watched the same apps through my Virgin box which is connected to the same Virgin hub two foot to one side of the Sky Glass TV. The Virgin box plays faultlessly.
Checked that wifi is off( it is).
disconnected the ethernet lead and reinstated the wifi.
Changed ethernet leads.
Changed ports in the hub.
reset the Sky Glass to factory settings then reinstalled.
tested the speeds on Betflix on both the Sky Glass TV and the Virgin box (it's around 91mbps on Sky Glass, 170+mbps via Virgin).
rebooted my router.
depowered sky glass.
depowered both sky glass and router simultaneously.
Hit sky glass with a sledgehammer (not really, but I felt like doing it!)
Spoke to Sky advisor who suggested the ethernet cable was probably getting interference from the wifi or electrical impulses, and to disconnect it and move the router further away...
I honestly cannot think of anything else that may be the issue.
The ONLY thing that has changed is that my Sky subscription ended...
Is there anyone else who is or has experienced the exact same as me please?
Hi @K11 / @Anonymous
Do you have WiFi enhancer turned on, on your EE router? They sent a botched update out a few weeks ago and it was affecting WiFi and ethernet cable devices. I have the 1.6Gb busiest home bundle but was barely pulling 200Mbps.
After a few days back and forth, they got me to factory reset the router and not had any issues since. While the router was running the dodgy version, I was seeing "wait for your program to load" message for a second or two when changing channel but then it was fine when actually watching. Now I'm back to changing channel and a very split second response time.
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
Hi Mike
unfortunately I have a Virgin router .
cheers
David
@Anonymous  You should've started your own discussion rather than add your separate issue to someone else's issue about EE routers🤔
Anyway you seek assistance directly with Sky CSs😉
It made sense to continue a still open post having the same issues particularly as it states "sky glass freezes -NOT using WiFi"
not a particularly helpful answer, probably best saying nothing.
Well ... the discussion had been inactive since the 5th of September and ended with specific information about EE routers😉
