Discussion topic: Sky glass/ethernet
This message was authored by Darrell2 This message was authored by: Darrell2
Sky glass/ethernet
Hi there, experiencing jitter, freeze and  loss of connection With sky glass, 2 days in from delivery..
broadband is super fast fibre so no issues there. 330mbps download , 61mbps upload
I'm attempting to run the Ethernet cable from router to the tv to improve things but keep getting an error,..
(If IP address allocation is disabled on your router, you'll need to enable this before continuing)
please help, I've looked into my hub Manger and cannot see anything related)
thanks
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Re: Sky glass/ethernet
Hi @Darrell2
Have you tried turning the Glass off at the socket then connect the ethernet wait a min then back on?
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
Darrell2
Hi there,
Just tried that, same error code.
thanks
@Darrell2  Have you tried rebooting your router?
Darrell2
Hi there,
yes I have, 3 or 4 times..
thanks
@Darrell2  Is this a sky provide router or another provider
Darrell2
BT fibre Halo
@Darrell2  Sounds like an issue with the hub itself  see these steps https://community.bt.com/t5/Archive-Staging/DHCP-Address-Allocation/td-p/1829030
Darrell2
Everything seems fine with the hub, tried Ethernet in laptop etc, was also working with sky q, everything works..
maybe I give Bt a call unless someone knows the answer in relation to sky glass
 cheers
@Darrell2 You could try a network reset on the Glass TV settings menu - advanced tab.
Darrell2
Must of done that a dozen times mate..👍
@Darrell2  Then it really does sound like a hub issue not allocating the IP address, try the reset that I linked to in my earlier reply.
I'm running a Glass television off a BT Smart Hub 2 over ethernet quite happily: there's been no indication in this forum of any incompatibility between Glass and BT routers.
Darrell2
Thanks, thought I was going mad, think I'll have to give sky or BT a call next week, I've reset absolutey everything..
