Discussion topic: Sky glass TV wall bracket
This message was authored by: Tammie56
I need a bracket so I can mount my sky glass on the wall how do I obtain 1 please
Re: Sky glass TV wall bracket
Hi @Tammie56
Is this gen 1 or 2? Gen one uses part of the table top mount and gen 2 needs to be purchased separately. You will need to call sky for this as we are fellow customers here on the community.
However both generations are compatible with VESA mounts as long as they are rated to take the weight. See: https://www.sky.com/help/articles/sky-glass-wall-mounting-guide
MikeAlanR
