25 Jul 2023 12:01 AM
Do VESA 300 x 200mm brackets fit the sky glass 65 inch tv?
On the installation guide with the plate that comes with the tv it states it's 300 x 166mm?
25 Jul 2023 06:52 AM - last edited: 25 Jul 2023 06:55 AM
Posted by a Superuser, not a Sky employee. Find out more@Bucky72 see my answer to your duplicate post.
You are confusing the arrangment of the wall screws on the included mounting bracket with the mounting points on the TV itself. The mounting bracket is not used if using a VESA mount.
